     Ähnlich wie das Debakel der Leistungssensoren
    Manual Uninstall :
Remember for Beta 1 you need to click on show updates to see the IE 7 uninstall entry in add/remove programs.
For Beta 2 & later you can see the IE 7 uninstall entry as a standalone entry, no show updates required here.
If you dont see the uninstall entires even after following the above steps then do the following -
* Go to Explorer/Tools/Folder Options/View - Enable the Show Hidden Files and Folders.
* Go to Start Menu/Run paste the following code & press enter(check the exact path in your windows folder)
o %windir%$NtUninstallie7bet2p$spuninstspuninst.e xe
OR
o %windir%$NtUninstallie7bet2$spuninstspuninst.ex e
* One other way to do is to manually navigate to the path shown above and click on spuninst.exe.
